Ready for our trip to France!
Good luck in getting over 30 mpg !!!!!!!
I usually average 35mpg but the last week I've had the roof box on and it's dropped to 30mpg
Are you chaps using the factory fitted towbar, or have you fitted them aftermarket?
Have a good time! Don't think about the mpg. You are on holiday.![]()
Didn't think I'd been too heavy too often with the right foot, but just noticed my Conti Contact Sport 5s on the rear are almost down to the wear bars after only 8500 miles...
That's on the estate, premium, pano sun roof etc.
Is it just me?![]()
I'm at around 12k, with probably fairly tame driving!, and not close yet.
A colleague went through a set after 9k in a 300h so I've been watching quite closely
The guy next door also has a c350e estate but his is on Hankooks rather than the Contis. Wonder if those have a better tread life - they certainly have plenty of wear left.. Anyway, two rear tyres replaced at 8800. Will keep a closer eye next time...As I have said elsewhere, at 13,000 miles my rear tyres were like slicks - thank goodness I checked because they had possibly been illegal for a thousand miles or so! At least they are reasonably cheap (£130 each fitted) When I had an EvoX it killed all four tyres every 12000miles and they cost over £250each!
Interestingly my tyres were worn evenly, even though I run the pressures at the high end of the suggested range and do almost all of my miles on my own and without luggage. The tyre company told me they see a lot of C350e tyres worn on the outer shoulders (under-inflated).
For all of you that are running heavily loaded, make sure you pump your tyres up to the maximum in the range.
My charging flap snapped off when I knocked it removing the charger. I feel it is not robust enough for persistent use and exposure to the elements. MB are refusing to replace under warranty, did you challenge this and how much did it cost to remove bumper and replace?Please note that the outer flap covering the charging socket is connected via a weak hinge and my hinge has fractured and broke off. I'm not too sure how this may have occurred and I can only guess that the flap has been knocked whilst the outer flap was open whilst left on charge.
The outer flap plate is approx. £9 to replace. However, the hinged section is moulded into the rear bumper and I'm waiting for Mercedes to quote the price for the full bumper replacement. I'm currently keeping the rain off the charging socket via the inner socket hinged cover.
I've expressed concern with Mercedes as to a potential design fault as it seems crazy that the petrol flap is a moulded removable casing around the fuel nozzle and yet the charging socket is moulded into the rear bumper and does not provide a quick replacement inexpensive part. :fail
On another note I have 17" Hankooks... hopefully those will get replaced by Michelin (our tyre policy) but I am not sure if tyres were included in the lease maintenance package or not (if they are then all bets are off).
