waisal
Hello
Unfortunately I have discovered rust on drivers side rear sill. I was doing some work on the rear brake and tried to place a stand just behind the jacking point and heard a crunch, thankfully didnt go all the way through but has definitely distorted the weakened rusted metal.
The jacking point it self seems relatively solid but I havent removed side skirts to check the whole sill yet also it has been waxoyled in the past so is covered in the an old coating.
I have looked through the threads and seen that it can be quite an extensive problem on some w202s so will have it inspected.Can anyone recommend a good welding/repair shop in the Manchester area. Also a ball park figure for cost if I needed a few points on the sill welding with new metal.
