C63 tyre setup question....
yes poor alignment could cause that - as suggested several times, get that checked otherwise you are shooting in the dark with guesswork
start with the simple, relative cheap checks before replacing anything
how many miles has it done and how old are the tyres?
Also check it doesn't have pikey wheel spacers fitted or the wrong offset wheels. If you are unlucky, they can mess up the ackerman and scrub radius, amongst others.
If you value low road noise and a more comfortable ride with very good grip then Goodyear or Dunlop would be my choice . If you just value ultimate grip (albeit a difference you might just notice on a flat out track day) then PS4s I'm afraid I fall firmly, or should I say more comfortably, into the former and absolutely love the Goodyears. Whatever wait till you need to replace before you buy a matched set. If it skips on Falkens then I expect it will do exactly the same on matched tyres.
Do the tyres have to have “MO” printed on them?
Front falkens done 500 miles. 45k mileage
have you tried swapping the tyres front to back?
Or, if they are not asymmetric, left to right.
And another +1 for getting the alignment checked at WIM in Chesham. A lot cheaper than new tyres due to premature wear.
I probably should be mine checked too.
I had my Exige's geometry adjusted by a race team and it transformed the car.
