D
Deleted member 37751
Guest
Got to be on the wind-up surely Ian? Lifted from Wiki:Innovation and Mercedes are not words you normally use in the same sentence
The internal combustion engine automobile was developed independently by Benz and Daimler & Maybach in 1886
Daimler invented the honeycomb radiator of the type still used on all water-cooled vehicles today
Daimler invented the float carburetor which was used until replaced by fuel injection
The "drop chassis" – the car originally designated the "Mercedes" by Daimler was also the first car with a modern configuration, having the carriage lowered and set between the front and rear wheels, with a front engine and powered rear wheels. All earlier cars were "horseless carriages", which had high centres of gravity and various engine/drive-train configurations
The first passenger road car to have brakes on all four wheels (1924)[76]
In 1936, the Mercedes-Benz 260 D was the first diesel powered passenger car.
Mercedes-Benz were the first to offer direct fuel injection on the Mercedes-Benz 300SL Gullwing
The "safety cage" or "safety cell" construction with front and rear crumple zones was first developed by Mercedes-Benz in 1951. This is considered by many as the most important innovation in automobile construction from a safety standpoint
In 1959, Mercedes-Benz patented a device that prevents drive wheels from spinning by intervening at the engine, transmission, or brakes. In 1987, Mercedes-Benz applied its patent by introducing a traction control system that worked under both braking and acceleration
an Anti-Lock Brake system (ABS) was first offered on the W116 450SEL 6.9.
They became standard on the W126 S-Class starting production in 1979 and first sold in most markets in 1980.
Airbags were first introduced in the European market, beginning with model year 1981 S-Class.
Mercedes-Benz was the first to introduce pre-tensioners to seat belts on the 1981 S-Class. In the event of a crash, a pre-tensioner will tighten the belt instantaneously, removing any 'slack' in the belt, which prevents the occupant from jerking forward in a crash
In September 2003, Mercedes-Benz introduced the world's first seven-speed automatic transmission called '7G-Tronic'
Electronic Stability Programme (ESP), brake assist, and many other types of safety equipment were all developed, tested, and implemented into passenger cars – first – by Mercedes-Benz. Mercedes-Benz has not made a large fuss about its innovations, and has even licensed them for use by competitors – in the name of improving automobile and passenger safety. As a result, crumple zones and anti-lock brakes (ABS) are now standard on all modern vehicles.
The (W211) E320 CDI which has a variable geometry turbocharger (VGT) 3.0-litre V6 common rail diesel engine (producing 224 hp or 167 kW), set three world endurance records. It covered 100,000 miles (160,000 km) in a record time, with an average speed of 224.823 km/h (139.70 mph). Three identical cars did the endurance run (one set above record) and the other two cars set world records for time taken to cover 100,000 kilometres (62,137 mi) and 50,000 miles (80,000 km) respectively. After all three cars had completed the run, their combined distance was 300,000 miles (480,000 km) (all records were FIA approved).
Mercedes-Benz pioneered a system called Pre-Safe to detect an imminent crash – and prepares the car's safety systems to respond optimally. It also calculates the optimal braking force required to avoid an accident in emergency situations, and makes it immediately available for when the driver depresses the brake pedal. Occupants are also prepared by tightening the seat belt, closing the sunroof and windows, and moving the seats into the optimal position.
At 181 horsepower per litre, the M133 engine installed in Mercedes-Benz A45 AMG is the most powerful series production four-cylinder turbocharged motor (as of June 2013) and has one of the highest power density for a passenger vehicle.
Half a century of vehicle safety innovation helped win Mercedes-Benz the Safety Award at the 2007 What Car? Awards.
