SLSWE
I got quoted Total 5W-40 for my upcoming service. Can't find anyone else running Total oil in their M156, is that a bad thing?
Wouldn't it be fine as long as it is 229.5?
I'm using 5w40 Shell Helix from eurocarparts every year or 2000 miles. A bit OTT but I also use Liqui Moly.
Also treat my engine to Redex octane booster now an then. I'm not a particular fan of the new E5 petrol with ethanol content.
Forgot mb, I say to mb they knew about the softer adjuster plates and about the T60 head bolts, but mb won't say anything about that specificallyMB say not to use any additive.
What is the Redex octane booster good for? I've never heard about anyone adding this.
Have you tried Motul X-max?Like I said, there's a good chance the invoice is wrong. On the one hand you've got garage monkey who knows mechanics and on the other you've got secretary monkey who knows copy and paste.
Any reason you don't use liqui moly or motul engine oil?I'm using 5w40 Shell Helix from eurocarparts every year or 2000 miles. A bit OTT but I also use Liqui Moly.
Which one? The dealership puts in Sinopec 5w40. I'm thinking Liqui moly green 5w40 or motul 0w40 X max. Unfortunately I can't find anything from Bob oil forum on motul x max.There are far better oils out there than the mercedes brand and others that have been mentioned
Which oils were rated 1st to 14th?At 15th place placed better than a racing Ester , Liqui Moly or a Motul equivalent .
Mobil is 15th, what about the rest? Share the article for a full disclosure.Anyone can recommend an oil or say a brand is best or believe every word on the packaging .
Luckily a mechanical engineer who researched tribology tested over 250 oils for oil film strength as #1 priority is to prevent wear.
Here's the top 40 grade .
Indeed.Which oils were rated 1st to 14th?
Shell Helix (5w40 fully synthetic oil) is a known brand and reasonably priced from eurocarparts, easily available and is 229.5. If you can let me know the cost of liqui moly oil or motel oil, I will research and consider it. I change my oil every year or every 2000 miles which ever comes first. So I do need oil which is easily accessible and reasonably priced.Any reason you don't use liqui moly or motul engine oil?
