Peterstu1
Anyone know the batch/code/serial number for the CD changer unit in the boot for a 2001 CL55, I need to have repaired or replaced??
Hi Pete, are you sure its the CD Changer and not the fibre optics that are causing the problem ? there is a way to test it. Regards
P.S. Are you getting the CD not found (or something similar to that) showing on the COMMAND screen ?
Hi Peter, pull the fuse (i think its F61 under drivers side rear seat, please refer to the link in my previous post), if the fuse is ok put it back in, then see if the system starts to work again. It should work for a while until the same thing happens again. If the system starts to work (touch wood, it should do) then the fibre optic loop is faulty. Hope this helps.
Just a thought.. Is the head clean?
I have a 6CD changer available.
Worked in a saloon but when I put it in my estate (different mounting) it jumps on bumpy roads.
If you know of anyone passing through Wilmslow who could pick it up, you could try it out and if okay I'd let you have it at a good price.![]()
Do you need a cleaning disc & fluid to clean the head or can you do it manually?
I'd just use a cleaning disc and fluid.
From my (clumsy) experience taking these things apart can be troublesome. I haven't touched the one I have now for fear of "fixing it" once and for all.![]()
