cd reading error update
mainsred
Newton Abbot, Devon
c240 elegance
hi folks
following on from my previous thread, had the dealer run a check on the comand system to remedy the problem with nav and audio discs. As expected, they advised a new unit was required at a cost of £1900 approx for the part. However they did not charge me a penny for cleaning the disc and looking into the problem - they even gave it a good clean inside and out !
So, can anybody recommend an outfit that will repair comand units preferably in south west but i do not mind travelling nationwide.
thanks in advance
Did you get anywhere in finding someone to repair the Comand system? I have the same problem & rang Blaupunkt who recommended OE Electronics in Calne. They will attempt to repair for about £85 but are not allowed to replace the CD drive itself due to the contract between Blaupunkt & Mercedes. If they cannot fix it they need to send to Blaupunkt in Germany for an estimate to repair.
David-B said:
hello
i had the exact same problem but was fortunate enough to have mine replaced free of charge under warranty
you can read about it here (post 20)http://www.mbclub.co.uk/forums/showthread.php?t=30951&page=2
but due to the uncertainty of my claim i also checked to see if the fault could be repaired and contacted these guys
http://www.braybrooks.co.uk/contactus.htm
who told me they could indeed repair the fault, the expected cost being around £400 which although not cheap is certainly much less than going through the dealer
hope this is of some help :)
Had my satnav serviced by braybrooks after merc quoted £2500 - did a good job and worked a treat after.
Problem is often dirty reading device which can't be cleaned without opening up the unit.
