Steve_Perry
They do? I got mine as a single for 20p + VAT.Originally posted by WLeg
These come in Packets of 5, so if anyone wants one, I've got 4 spare....
S.
Some dealerships will respect the "minimum quantity" on some orders, some wont. If a stealership has them in stock then they will probably sell one, if they have none in stock they may want you to buy the whole minimum quantity order.Originally posted by Steve_Perry
My dealer was out of stock and had to order one especially for meOriginally posted by Shude
Whenever I disconnect the battery I make sure I have at least one door unlocked and that the rear seats have been unlatched, so if I need to I can get into the boot and reconnect the battery that way, both my driver's door lock and the boot lock are siezedOriginally posted by Simon
Steve,
Thanks for solving a problem for me. I’ve been wondering how to make a good job of blocking the keyhole but never thought of that, doh! And there’s one in my door handle I see every day!!
I want to do it because when I disconnected my battery and shut the boot lid – big mistake, it took ages to un seize the lock and get it open again.
Cheers
Shude said:...See that? List price is now 75p on these little rascals!
It's amazing what that can do, it once knocked 17 quid off a service for me.Shude said:I pleaded poverty and got a couple for nothing.
Neither have I, so do your locks actually work or are they siezed like mine, I haven't bothered with trying mine in ages.Shude said:I put one on the door handle lock and other on the bootlock (I have still never actually used either lock!)
I've not tried them so I don't know, might have a go with them tomorrow. It would be nice to know that I could get into the car with the blade-key, it was about £7 after all!Steve_Perry said:Neither have I, so do your locks actually work or are they siezed like mine, I haven't bothered with trying mine in ages.
When you press the modelupdated 97+ trunklocks - the lock is vacuum operated (the lock is just a switch)...but when the trunk is open and the trunklight is on - you can press the lock as often as you want - but no vacuumpump noise - untill you switch off the trunklight (disconnect the ground in the trunklight switch).Shude said:When you press the button, I think it still uses the solenoid, try opening the boot and then while it's open press the button and listen...you hear a mechanical/motor type noise!
