grober
MB Master
Can anyone give me a method for checking the front suspension ball joint play. I know in the MOT test they raise the front suspension arms by jacking them up with the wheels still on the ground but I'm not sure exactly what they look for? Do you look for movement as you are jacking up or when you let the suspension arm down. How much play if any should be present. Exactly where do you position the jack etc etc. Maybe someone knows of a post pref with pics which gives the answer??
