Ian B Walker
- Jun 7, 2003
- Location
- Freckleton
- 300-24, saloon and coupe, E300 24 valve diesel estate
Steve ditch the 211 and use Carols 124, you know it makes sense
This is why I said that if this only blows when the car is running, then it is one of the over voltage problems that can affect the 211
Has the unit been tried in another car since it blew the fuses? it could be that removing it from one car to another has caused a short in the cable or unit.
It might also be worth checking the voltage output from the socket just in case that has caused a problem with the Satnav, unlikely though.
But with 2 different units? Does sound as if it is the over voltage issue.
And even if the output voltage did float up, it should damage the Satnav, not blow the fuse.
More likely it would blow ht eheadlight bulbs first though.
Try the satnav in a different car then report back.
Thanks all - you guys are da bomb!
My money is on the over voltage issue, but I'm not able to get the car in until back of September (work very busy plus holiday/French GTG!!)
Looks like I am going to have to live with it until then
WARNING - VERY DUMB QUESTION
The satnav thing fuse (it's not the actual satnav but rather a brodit holder thing with a small speaker and captive power lead) is 1.5A and the ipaq charger is 2A. Would it hurt if I just doubled the fuse size for the moment?
TOLD YA IT WAS DUMB!!
Yeah, I had been thinking about the possibility that for example the fuse had been replaced by a slow one, but it still all boils down to marginal differences between the two usage scenarios, which seems odd as an explanation for this behaviour...
A multi meter for £5 would tell all
