Jan 25, 2008 #1 O onesongrg New Member Joined Jan 30, 2005 Messages 10 Hi After filling up the car today my srs light has stayed on on will not go off? Can any body please shed some light on what might course this? Ta Roy
Jan 25, 2008 #2 television Hardcore MB Enthusiast Joined Oct 5, 2006 Messages 12,269 Location Dorset on South Coast Car R230 SL500 I understand its normally the set pad passenger side or a bad connection under the seat A fault code can be read out
Jan 25, 2008 #3 S speedybiker Active Member Joined Apr 19, 2007 Messages 368 Try and clean the seat belt connector's. I think it has a sensor that works with the airbag. I had the same problem and that sorted it. I read it on a forum. I'm sure it was on here Alex.
Jan 26, 2008 #4 OP OP O onesongrg New Member Joined Jan 30, 2005 Messages 10 Thanks Guys Will check it out !!!
Jan 26, 2008 #5 KillerHERTZ Administrator Staff member Joined May 21, 2003 Messages 19,455 Location Cambs Car SL63 AMG This should be the problem, the small cable needs to be fed into the yellow socket. Was anything in the passenger footwell at the time? anyone sat there? Last edited: Apr 14, 2010
