CLK 55 Niggles - headrest, lumbar and light wash
vanman1936
CLK55
Few minor niggles on the CLK55 (209) - any tips appreciated.
Headlamp washer not working
Driver side head rest worked until recently - now nothing.
Passenger lumbar electric adjustments (buttons on the right hand side if passenger seat) - intermittent.
Cheers
P
I've posted somewhere on the washers, on my C32.
Run some power to the pmp (under the nearside wheelarch liner) and check that the pump works. Mine had simply corroded up. I pulled the pump off IIRC, and tried to activate it with 12v from my desktop battery charger. Well siezed.
The headamp washer is the cunky one, that you needed to pull off a clip to get the hose off from (you'll lose all the fluid in the bottle too. Has to be chunky as the water pressure is what powers the protrusion of the jets.
On my 209 the air tubing to the seats would occasionally come loose, just need to reseat onto the little connector under the switch block next to the seat.
