CLK C209 number plate bulb
D2028
Northern Ireland
2009 CLK 220 cdi avantgarde, 2004 landrover discovery2 td5
Any recommendations for an led bulb or sealed led unit to do these, I hear many canbus horror stories. Or should I just replace with ordinary filament ones?
I thought that might be the case, thanks for confirming it, I assume it's as simple as removing two screws and the clear lens to access the bulb?
Replaced both of mine a few days ago, easy to do you just need to make sure you get the right sized festoon bulb as there are different lengths.
Ordered these
239 OSRAM Ultra Life 12V 5W C5W 38mm
Stick to original, had nothing but problems with LEDs, canbus compatible etc nothing worked.
Tried 3 times with reversing lights, last set now fitted to my 190B and appear no brighter than original bulbs.
