Looked at a 2000(W) CLK Cabriolet. Spec is pretty basic (doesn't have a centre console).
However, the dashboard showed at least 2 errors during the test drive. The first was shortly after starting up, something like "1 system error", which the seller put down to the windscreen washers???? The later error was more clear and indicated that one of the bulbs in the front light cluster was failing, although the lights appeared to be ok.
Its the first error that worries me - should I be concerned, or is it likely to be what I was told - due to the windscreen washers water being empty?
Is there a guide somewhere on the internet that explains how to diagnose the cause of the system errors, or is a main dealer the only option to get it checked?
NMK
NMK
