clk w208 roof will not retract
gumbumper
Hi, my soft top will not open, everything works in the right order until the roof lift, then it moves slightly then kind of times out. If I push it there doesn`t feel like any power to lift & the fluid level drops slightly, no evidence of a leak, the roll bar lifts ok. (rear panel removed to access the pump)
thanks in advance-
thanks in advance-
It would appear from post here that the motor can fail, and no one can supply any parts or the motor, this meaning that the whole thing has to be replaced. This can be confirmed with a read out on STAR,, a good indie will do this, let us know the outcome
Welcome to the forum, and sad at your not such good news
Just replaced the pump unit with a s/h good unit. motor seems good @ o.5 ohms res`, switch on load cover overidden. Is there some sort of pressure switch, to stop you overloading the motor, say if your trying to lift the roof in a garage, failing that anyone know of a hyd` or electronic scematic for the roof?
Put your E mail address up for a few mins and I can send some details
You can delete it in a few mins when I say
big thanks teev.
seems like all the w208 owners get roof problems :S argh!!!
Definitely sounds like a limit switch problem to me. What is the last part of the sequence which works properly when you try to open the roof? The boot lid cover opening?
Result! - Took it to Mercedes Truro for a diagnosis, found a sticky switch, freed it, & adjusted a pressure setting,roof now working fine, also checked for a seat signal malfunction & a slight start up miss-fire all for the princely sum of forty quid & they washed it too! Thanks to every reply,& after a week of arsing around with it myself & not wanting to take it to Merc, turns out they weren`t a stealership after all.
