CLK200 W209 Vibration Issue
117
Exeter, Devon
BMW 650i Sport, Range Rover V8 Autobiography, Ex 01' S500, '04 C200 CDI Coupe, '95 C200
Hi Guys,
Just purchase a 2009 CLK200 Kompressor convertible automatic
I am having an issue that when holding the car on the brake at a standstill, I feel a vibration through the entire car, in all other situations the drive is faultless and if you change into neutral everything is as normal. In D or R with the brake depressed, the car is holding about 600/700 rpm, is this normal?
I suspect that it could be caused by worn transmission or motor mounts, as the car is high mileage, any other suggestions?
Thanks in advance guys
