Hi Larby
I've just come across your thread as I'm looking more on this site now (I'm a regular Stateside).
I don't want to burst your bubble but you really would be better/cheaper off selling your car and buying a CLK55 AMG.
I did the 55 conversion a couple of years ago and it wasn't cheap!
Yes the engine will drop straight in but you will have ECU problems.
Firstly the 55 ECU and engine harness will not work on a 430. The 55 ECU is physically diffferent and the harness has a few extra wires on it for an extra pair of O2 sensors and a secondary air pump (used for emissions).
Yes, you can use your own ECU and engine harness but the 55 engine will perform like a 430! You will have more power and torque low down and mid range but you will have no power up top.
The C43 can use their ECUs because they have an AMG ECU, it will self learn so tuning isn't necessary.
You can order a 55s ECU but it will need to have your chassis number on it (very hard to get). Mercedes do not like modified cars! DO NOT BUY AN ECU FROM ANOTHER 55 it won't work (chassis coding again).
There are 3 main computers in your car and all three have to agree before your car even starts!
The ECU not only controls the engine but your electrics in the car.
The 430 uses the block of the C43 but not the heads! If you look on the front of your engine block you should see an AMG stamp too. This is because the 55 is an enlarged version of a 430 albeit with different hard ware.
The only way you can use your 430 ECU is if you have a custom tune spending a day or two fine tuning the programmes! It will cost you!
You can use your gearbox because it is the same as a 55s. You must have a speed shift from '00 onwards to make it work. Shift times and torque limits in the TCU are different too. Yes you can have them altered but again it will cost you. I did not alter mine and it hasn't hurt me (although I'm getting it done just to see the difference).
There is no point in changing your drive shaft or rear differential they are the same as the 55s but have small changes. The shaft has 4 lugs not 3 as on the 430. This was done when Mercs were made properly and over kill was the norm. Your car can handle 500+ hp. The diff is marginaly different in gearing, slightly higher geared with the final drive for the 55 (2.82 on the 430 Vs 2.82.1 for the 55). This suited the characteristics of the 55s box.
I'm sorry to say but your exhaust is not an AMG exhaust. The 430 has a smaller diameter pipe all the way back from the headers. You probably just have the back box.
The brakes and suspension I can believe are AMG. It is HIGHLY unusual for your car to come from the factory with them but not impossible. If however you measure your brake disc and it isn't 330mm they are not AMG.
I don't mean to be blunt but this is coming from experience. You will tie up £5000+ in this conversion!
My car is quite special in the fact that it has celebrity connections and it being a cabriolet with a custom made hard top too! At the time I bought my car the 55AMG Cab had not been made so I set about making one. If your car is a saloon to be honest there are plenty of good ones about. If you love your car though, do it, but it will cost you more than if you were to buy a used 55.
If you decide to go ahead......nice one
Customising a car is very personal, some people won't get it but it will be as individual as the owner
