cls transmission issue, cant get reverse
fudge1984
WARKS
SL350/S320CDI/CLS320/W124E220/FF RANGE OVERFINCH STYLED
hi all
have a 2006 cls 320cdi (obv auto)
on start up its fine selecting reverse
once the lever down to D or N it wont move back into R (and therefore P), just refuses to go up and obv I dont want to use excessive force. However once in a blue moon it works fine! engine temp has no bearing on weather it decides to work or not. just a nightmare as i was getting into a restoration project and this happens!
The only way i can get it to reverse is it turn the engine off, move the shifter into P and then start the car and select reverse
now you can imagine trying to do a 3 point turn with such a problem
anyone shed any light on this as this a new issue to me! o its done 110k with fmbsh.
also its got no warranty not that they would of helped!
thanks in advance for any help
Might be related to a duff brake lamp switch above the brake pedal. Cheap from MB, might be worth a shout?
many thanks for the reply
worth a shot at that price, will try it out
thanks mate
It could be a faulty selector module. It needs a Star to confirm.
resolved!!!!!!
thanks guys
changed it, ten mins job, £10 odd quid
jobs a good un
whitenemesis you are the man
thanks all, be wary of these little switches!
Sorry to appear a dummy but trying to learn quickly:rolleyes: but how does a duff brake light switch prevent selection of reverse?
Probably because the car will think it is still moving?
yeh i think the sensor seems to make the car think there is load on the engine hence the refusal to select gear
i maybe wrong, just a theory
Hi guys I have the same issue i have replaced the brake switch but still have the issue any other suggestions
Get it plugged in and retrieve fault codes and post on here. Out of curiosity; when was the last time the transmission was serviced? I know the valve body and conductor plate sometimes go on these.
