PhilWainwright
Hi All,
I wonder if anyone could offer some advice. I have a CLK 200 Kompressor (1800 engine size, 2002 model) I do apologise, but I have no idea what the W number is that you experts seem to use.
If you look at the video link, you can see the rev counter, and hear the engine. At this point, the accelerator makes no difference. The error message does say ESP fault, but I thought that was connected to braking not engine running..... although I could be mistaken.
However, if I tap the top of the Throttle Body, it usually cures the problem (coincidence, possibly) but I thought this was the issue. So, today, I have removed the throttle body and cleaned the butterfly and the housing with carb cleaner. I carefully removed the cover over the electronics and cleaned the fingers and the resistance tracks with contact cleaner and lubricant...... I turned the key, and yes; the problem remained. The problem is getting worse with time, and also the cruise control/speed limiter also now becomes inoperable..... it is getting worse over time.
I replaced the MAS only a couple of hundred miles ago, as a local garage said that was the fault code that was showing. Still no difference.
Does anyone have any thoughts on why my car is behaving like this?
Please help[YOUTUBE]YouTube[/YOUTUBE]
YouTube (youtube link)
