Cold starting
Colin Mckenzie
Mercedes R series
Posted earlier about my cold starting problems, fitted 6 new glow plugs, yesterday had new relay fitted, this morning same problem, light comes on for 10 seconds, start engine, cranks for several seconds catches, then rough running for a few seconds then perfect, light comes on again for approx 30 seconds, then goes out. Any ideas?
I was thinking of disconnecting battery for a few seconds to see if this would reset everything, what do you think?
I would be looking at a possible fueling issue like injectors. Needs to be plugged in firstly.
The new MB glow plug relays are modified and look very different to the old type.
Contacted them and am going in on Monday for them to run diagnostics check.
