amwebby
I finally worked out how to access the COMAND Diagnostic Menu from my 2.5 COMAND. Prior to the MY2001 update you could use the Mute+1+3 button press method from SYS. Once I'd upgraded to MY2001 that simply wouldn't work. As I have no Aux input that wouldn't work and I tried switching to Tape but that didn't work either.
What I discovered today was that it DOES work from TV. This is on a W215 so you might want to update your instructions on mercupgrades Richard.
This is what I found.
I now understand why I never receive a text message when I miss a call as SMS is not enabled. Is there an easy way to enable SMS or does this require a visit to the dealer, paying the accompanying charge?
In addition I'm currently looking at upgrading from the Motorola fixed phone to the early Nokia fixed phone, would I have to do this all over again after that?
I also see that the D2B bus is configured for the CD Changer to follow the BOSE amp on the D2B ring, as you would expect, followed by the telephone. However it seems that the Telephone is after the amplifier, then followed by the CD Changer. Is there an easy way to fix this? I.e, can I reset the config or is there an easy way to swap the Telephone and CD Changer so their actual position matches the config?
Edited to resize pictures.
