Over the past few months my Comand system will suddenly mute for no apparent reason. This is coupled with a flash of the all the Parktronic lights on the top of the dashboard.
If you leave it, the sound comes back after a few seconds or so (maybe 10-15 seconds). If you turn off the system, or press any button apart from the Repeat Last Instruction button, it remains muted. If you press the Repeat Last Instruction button, the last command is repeated and the radio comes back on !!
I have taken out and replaced the 40amp fuse in the rear fuse compartment in an attempt to reboot the system, but no difference.
The one thing that I have now realised is that this only seems to happen in cold or wet weather ..........
So, any ideas anyone? Its no big deal but part of that great mystery which is the electronics system in an 04 W211
Did I ever tell you about the telephone module behind the rear seat that fails if you screw down the plastic panel that covers it and the other two modules ........ leave the screws out and its fine
