Comand ntg2 hang up problem
hercules
Kent
W203 2006 180K Sport Edition & ML164 sport
I noticed from yesterday that my comand is hanging on the MB boot up screen and nothing else is happening , it wont even eject.
Is this caused by the latest cold weather or is there an other problem.
I left the car heating on for about 30min and still no results.
Any one had similar problem.
Try removing and replacing the fuse in the fusebox for the Comand to reset it.
Thanks I had in mind to do this , but I have the feeling that it might be a MOST loop problem , will investigate and will post in the forum
Yes npuk ,you were right, removing comand fuse for few second did reset the HU
I just found out how to eject my DVD nav Disk, I do not know if this is normal but it is working.
I'm helping my daughter to decorate her house and I was in need of a break so I decided to go my car and finish a pack of M & M that I left in my glove box. While I was there the comand was off and I decided to press the eject button, and I was amazed the DVD ejected.
So I have found out that to eject the DVD , the comand and the IC has go off.
Weird.........:confused::confused::crazy::crazy:
My COMAND will eject the disc when switched on?
