COMAND NTSG2 play music via bluetooth
Gazzer113
Mercedes clk320 cabriolet
Hi, all,
I have a 2004 MB CLK 320 Cabriolet VIN No WDB2094652T036524, a VISEEO MB 4+ and an Apple iphone 6 plus.
Is it possible to play music stored on the phone through the COMAND system via bluetooth and, if so, how?
Many thanks in advance
Don't know if they were installed on the CLK, but my B Class has a socket in the glove box for connection of my iPhone, not sure if bluetooth works with NGT2.
I meant if it had the ipod kit fitted.
It plugs in to where the cd changer would I think, and gives you a apple 30 pin connector.
You can then plug that bluetooth adapter in and it will give you decent bluetooth audio.
Hi, gIzzE,
Thanks for your replies: No I don't think it has the ipod lit fitted. It does have the 6 CD Multichanger.
I may consider the Viseeo MBU-3000 though
Thanks, again
Hi, Benzowner,
There is an audio socket in the glove box which works intermittently. Last time I tried it cut out when the phone paired with the Viseeo. I also wanted to avoid trailing wires where possible.
Thanks for your suggestion, though
They also do a 3.5mm line in bluetooth as well. It is about £16. If you have an aux input, cheap, you could simply add that.
The viseeo is not well regarded for bluetooth audio, I looked into it.
Hi, all,
The MBU3000 isnt suitable for your car. It wont work properly.
The car is actually a model year 2005 version so you can fit the Mercedes ipod kit to the car.
https://www.commandonline.co.uk/mercedes_ipod_ntg2.html
