I use CC all the time, on the flat, uphills, and motorways. I definately get more MPG using it.
Only downside is when I'm cruising along and proceed to go downhill, the car speeds up and I have to brake to maintain desired speed, at say 30.
So do you get best economy by driving at a constant load (speed) or by accelerating as fast as possible and then coasting down to a low speed?
No vehicle will get good fuel economy if you floor it.So do you get best economy by driving at a constant load (speed) or by accelerating as fast as possible and then coasting down to a low speed?
All fuel economy runs are done by getting the car into top as soon as possible, but as said that is not by flooring it, just do it quickly and gently it also helps to have some for sight so that you come to a stop almost without using the brakes
Would like to see accurate comparisons for the case where the same travel time would be assumed with and without cruise.
If you sit on cruise near the limit on a long stretch of road you will get passed and repassed by some vehicles several times over. Upshot is the drivers are doing about the same average as you but varying their speed a lot more. In most cases they are probably being less economical (the higher speed segments have disproportionate drag that is unlikely to be offset by savings from the lower speed segments).
On the other hand you see drivers who are probably on cruise come up against the tail of a queue of slower traffic and the brakes come on last minute as opposed to coasting up to safe distance behind the queue with no braking.
I couldn'd agree more. This happens to me all the time on long drives, mostly on the M74 / M6 north.If you sit on cruise near the limit on a long stretch of road you will get passed and repassed by some vehicles several times over. Upshot is the drivers are doing about the same average as you but varying their speed a lot more. In most cases they are probably being less economical (the higher speed segments have disproportionate drag that is unlikely to be offset by savings from the lower speed segments).
It can also be very annoying when they pass you, then they slow down, then you have to pass them, and the same happens over and over again.
The advantage with distronic is that you can set it to keep a 2 sec gap, that is 100m at 70mph and is OK if you are happy to sit in one lane. I find that for the best part that is fine as you can use the throttle with upsetting distronic, so if the lane that I am cruising starts to get messy,I just go by them all and let distronic take over again, it only decouples if I touch the brake the same as on cruise control
If going up a long climb,in cruise the box can kick down to maintain the speed, where as without you can coax it up without
Sorry Hawk it is not far fetched, try my turbo charged V70R it will change down at 70 on a long climb to get you up to cruising speed again quickly, where as with out cruise I can keep almost the same speed and the box not changing.Oh Malcolm that really is as farfetched as one can get. I use cruise a lot and have all my adult life mainly doing 40k per year. It consistently uses less fuel than driving oneself.
Staying in too high a gear going uphill does not save fuel. See any manuals on how to drive economically.
Manuals or books do not apply to driving an automatic in this instance, as its normally always in the right gear at the right time.
If you read all of the preceding post you will also see that if the car was driven in a leisurely manner before you engaged cruise the changes down in cruise are far less the had you been belting the car and then going into cruise.
Though my 2.3 V70R has the same BHP as my SL500 the V70R has to work hard to keep up and in cruise it will change down on motorways and without it it will not.
This is all fact and not fiction, as when it changes down it annoys me.
There has been many post on the same subject and most say that cruise is not always more economical
OK let's say with some cars there are some situations where you can do better than cruise. On hills may be one. I am talking mainly Mercedes diesel autos where the torque is so huge that gearchanging is rare in situations where you sensibly have cruise on. Normally cruise is most used on motorways where as several have said it has 100% concentration, keeps a constant speed and saves fuel.
Many also use it nowadays in speed limited areas to save watching the speedo all the time. Once again it keeps a steady speed and saves fuel. In complex situations and variable traffic it is far less useful and then I don't use it.
