DAS version coding for "electric blind for rear window" ???
perdikoyla888
I have a w203 pre-facelift. After retrofitting rear roller blind, WIS suggests to perform version coding for "electric blind for rear window" but checked out DAS menus and could not find version coding for "electric blind for rear window". Is there such thing on DAS as version coding for roller blind or not? If yes, could you please tell me where exactly is hidden as I checked it out for hours but could't find it? I cannot get my roller blind to work. thank you
Did you look in EIS ?
Just double checked all EIS submenus. Nothing there. Can you have a look as well to see if you find anything for coding roller blind? I do not see anything but WIS states that coding has to be done for roller blind. Just trying to rule out the possibility that it is coding that causes my roller blind not to function.
Also can you check in your car if the green rollerblind relay makes a clicking noise like if there is something loose inside if you pull it out and shake it? I know my relay is brand new, just seems that there is something lose inside the relay and do not have another relay to compare and see if it is indeed normal the clinking noise inside when you shake it.
thank you miro
I found it, thank you miro ;-)
