- May 7, 2007
- Lexus RZ300e Takumi 2025
You could've cleaned it before taking it in ...
Sadly no...You could've cleaned it before taking it in ...![]()
Had mine done yesterday. It's astonishing how such small adjustments make such a large change. It's like driving a different car. The bloke did mention that the near side front caster could be adjusted using a bolt but if I was happy with the way it drives not to worry.
Anyway, thought I would share.
Cheers.
If that's all you don't understand you're way ahead of me! I haven't had a look at said bolts....now I'm going to have to! I suspect having the bolt done will throw everything out of whack again. At the moment I'm happy with the way it goes down the road so I'm leaving well alone.What I don't understand is unless you change to suspension arm bolts for a cranked bolt how can it alter anything. When I changed my arms although the holes in the arms were elongated it has locating tags but straight bolts ?
Regards Ken
So you change the bolt?. I thought you maybe turned it but my bolts were straight so was puzzled.There are a few different types of adjuster bolts but the most common is a bolt with two grooves along its length. The bushing on the lower arm and control arm has four rails along its core, two left and two right. The bolts groves feed along one side of the rails left or right depending on what direction each angle is being corrected.
Got it.This will give you some idea what the bolt looks like:
And see also here:
Castor Camber/Castor Fluted Adjustment Bolts Question. - MBWorld.org Forums
That's neat.This will give you some idea what the bolt looks like:
And see also here:
Hi WiM, I've read this with interest. My S211 E500 regularly ends up pulling to the left. My 'man' has a hunter alignment system but I reckon that with the potholes and everything, I have to probably have an alignment done three or four times a year. My Falken FK501s were all worn on the shoulders after around 24,000 miles, as I didn't respond quickly enough to have the alignment done.
I have a couple of questions for you:
- when you align the wheels and install the grooves adjustment bolts, do you also ensure that the ride heights of the air suspension are correct?
- once installed, will my 'man' be able to make micro adjustments as and when required, or will the car still need to be brought back to you for a little 'black magic'?
I'm in SW20, so not a million miles away and am going to be swapping the summer alloys back soon, so probably an ideal time to consider your service.
Not sure what you mean by "a normal straight car"... If the camber of the front wheel is within the MB spec, then there's no need for an adjustable bolt. It is only needed on a wheel where the camber is out of the permitted range. The only way to accurately measure the camber these days is on a wheel alignment machine (I don't believe anyone is still using the mechanic camber measuring tools of old). The effect of a misaligned suspension can be unequal tyre wear, or increased load (and wear) on suspension components, and change of driving characteristics. With regards the latter, Tony Bones at WIM can advise - e.g. if you want to tune the suspension for sharper steering response or better straight-line stability at high speed etc. That said, many drivers won't notice a misaligned suspension, as long as the tyres don't seem to be wearing abnormally.That's neat.
I was expecting bolts with the centre section offset.
You would think though on a normal straight car standard bolts should be ok.
I changed all arms in mine and had it aligned and the steering is spot on.
Understood.By Straight I just meant a car that has had no accident damage or a damaged subframe.
Thanks Ken
