Direction Signal Arm faulty
sub_zero
kuwait
W124 E220 1995
Hi Gurus,
I have a w126 1986 ,I noticed few weeks ago that the direction indicator arm (that activates right and left direction lamps),is faulty,that is when I go right ,I just raised it up,but no signal activates,when I go left,I push it down,and it works.Does it need a fix? or should I replace?
thanks in advance
Does the indicator stalk lock into place and cancel properly? If so have you checked your bulbs?
Even if all bulbs have blown on one side of the car I think you should still hear the relay ticking.
Do the hazards work ? Don't know if this will simply activate both circuits or wether hazards are a seperate circuit.
