Been meaning to sort my front brakes out for a little while and thought I'd pick the forums collective brain about it.
I'm pretty inexperienced when it comes to car maintenance. I've done bits infrequently, a few oil changes, changed the sump once, things like that. It was ages ago, but I have helped a mate change his brakes and bleed the brake system in his car. And I've got a couple of experienced contacts that can help me out.
I've decided to give it a go as it would be a good learning experience.
My car is a 2001 clk 55 AMG and, I'm pretty sure it doesn't have any SBC complications.
I've had a scan of the forums and found the following quite useful
http://www.mbclub.co.uk/forums/wheels-tyres/60474-w220-needs-new-pads-discs-diy-not.html
Okay, the brake job... - MBWorld.org Forums
http://www.mbclub.co.uk/forums/wheels-tyres/22662-changing-disks-pads-clk55-w208.html
http://www.mbclub.co.uk/forums/wheels-tyres/14735-quote-discs-pad-replacement.html
There's also an endless stream of videos on youtube covering all aspects of brake maintenance. I love the internet.
Going to do it over the hols so have plenty of time.
I've had a look at what the workshop manual (WIS) has to say and it calls for removing the caliper and brake hose completely. None of the other advice I've read says this and usually recommends leaving the brake caliper attached to to the brake system and use the bleeder valve to release brake fluid pressure whilst compressing the caliper piston. Despite that, I'm thinking complete removal might be the way to go, because with caliper detached, I can give at a good clean and maybe replace the hoses whilst I'm at it.
Maybe there's a lot there for a novice like me, but this is going to be a little project for me over the hols. Hoping that the extra time, and a little help from more experienced friends will see me through.
General comments are welcome, but I have a few specific questions.
The workshop manual recommends replacing a 'micro-encapsulated bolt'. I think micro-encapsulated means the bolts that are sealed with a locking compound, so that would be the bolts that hold the caliper holder to the err.. thingy? So they're single use? I couldn't figure out what the part number is for this, perhaps I'm just looking at EPC wrong, but I just can't tell which one it is. Or is it just a standard bolt size, or maybe they come with the brake pad kit?
I was going to the do the brake sensors as well. Eurocarparts has some listed as 'Pagid Brake Sensor'. I'm guessing these will fit in OEM pads?
Any comments and tips would be much appreciated. I'll try and keep notes on what I did and post some pics up on the forum when I'm doing it.
