I have a merc cl500 w215 2002 in my workshop and have a problem with the drivers window and door mirror,
The customer forced the door mirror out when it would not fold out on it own, the the drivers window will only go up and down on the mirror adjustment switch, if you press on of the window switches the boot lid will open, bit of a head scratcher.
Have checked the wiring in the A post, no faults found, check the window switch panel and repaired a dry solder joint, still no joy, i suspect the the main seat memory control unit may be at fault,
Has anybody had a fault like this.
any help would be great.
Andy
Andy
