Driver's window rattle + strimmer rasp !
garystu1965
Lytham St Annes
Mercedes E350 CDI Coupe
Come on folks help me out here I'm sure some of you have experienced these rattles and have the solution to it....
1. Metallic sounding rattle - I've now worked out it's coming from my driver's window in the top right corner (right next to my ear). It's like the window is very slightly loose. When I press my finger against it it goes away. Can I do anything myself or is it a trip to the stealer ? This looseness may explain the wind whistle at 70mph. It's very annoying.
2. This one is wierd and is very noticeable...At low speed when revving I sometimes I hear a very noticeable sound that seems to be coming from the front trim. It sounds like a grass strimmer ! It only happens at certain speeds or revs (say between 20mph and 25mph) and then disappears. I am absolutely positive it is something on the trim vibrating at a certain frequency. But can I find it ? No luck so far. I've fiddled about with every button, COMAND, vents, speaker grill at front to no avail.
Any ideas ?
Any ideas ?
Interference from the charging circuit?
Does it get worse when you put a load on the alternator (main beam, hrw etc?)
