E Coupe W207 Rear Electric Windows
johny5_uk
in a house
E class
Do the rear windows not have a one touch function to make them go back up?
I can feel there is a double click when you push the button to open them, and they go down all the way but pulling up two clicks doesn't work and you have to hold to close the windows?
I am guessing that this is a "safety function" so as to not trap fingers in the back but with no one ever being in the back I would have liked one touch to close?
What does your manual say? Have you tried to calibrate the window(s), press the switch all the way and keep it pressed a couple of seconds still after the window has reached its end position.
Ah, manual says "When opening or closing the front side windows you can start automatic operation. Briefly press the switch beyond the point of resistance in the corresponding direction. By pressing again, you can stop automatic operation."
I guess thats a no then and they just used the "double click" buttons on the fronts and rears to save making a single click button :/ .
My w208 is just the same.
two position switch, but no 'one touch up' on the rear.
Front is as expected.
