e250 cdi ?? remap
delb0y
UK
W124 300 E // W211 320 cdi
Guys I'm in the market for a decent pocket rocket was looking at the e63 but I'm not bothered about the top end speed useless on uk roads unless you like points and fines!
Getting the fastest 0- 60 is what I'm after.. could someone tell me which would be the best me of new e class to get that can be remapped only without dpf or erg work as it will be leased ;)
Type of remap and gains I'd get I understand the e250 and e220 are the same engine ? With a different map on the 250? Or am I wrong
Cheers
A mapped 250 should be good for 250 bhp. The mid range speeds will be superb. Might be an ecu out job.
250cdi cdi have bigger injectors.
No need to open the ecu, goes with cable.
Usually power between 260-270hp and torq 600nm.
C 250cdi 4WD aut.
~268hp/600nm
