mjrose
I'm having some intermittent power loss (usually at cruising) on my 95 w124. The power will start to bleed off and on causing erratic (but gentle) decelaration and acceleration. Following this two things happen, either it will return to normal or the power bleeds off almost completely, car slows and lots of smoke appears out back from the exhaust.
If you stop the car, it will stall but start again, albeit roughly and then quicly return to normal.
The engine is otherwise in fine health; smooth, strong and no smoke.
I was thinking fuel starvation, but last time it happened i opened the bonnet (when running rough at idle after restarting) and there seemed to be plenty of fuel in the lines???? I couldnt tell whether it was flowing though!
Has anybody had a simialr problem??? PS i'm running straight diesel, and the filters were changed recently.
