ticex
Hello again!
I have had an ongoing saga with the repair of my serpentine poly-v-belt mechanism and belt by the main dealer in Brussels last month. To cut a long story short some tensioning spring thing that connected to the tensioning pulley was duff so after 3 trips to the garage they managed to stop the belt slipping and fitted a new belt.
Ever since they performed the last repair I've found the Power Steering rather heavy and when the engine is started from cold the belt makes a kind of squeeking noise. I understand this belt also drives the PAS pump so suspected right from the start they hadn't done something right but after a huge debate with the mechanic at the dealer I gave up and hoped all was ok. However, now the weather is getting colder I've noticed the lights are much dimmer when the engine is cold, the steering is even heavier when starting from cold and the funny noise from the belt is more pronounced until the engine has warmed up a bit. The steering problem is a bit of a pain as my car has speed sensitive steering so it is bearable when parking but out of town it does really get quite heavy. I'm currently back in Edinburgh but will be in Brussels with the car next week so am considering going through the hell of visiting the main dealer again to try and sort this out - it is kind of a principal thing as they have charged almost £200 for all the various repairs on this thing!
As this belt also drives the alternator I think I'm correct in assuming something is definately not right but I'm in the difficult situation that the dealer is not interested unless I can tell them exactly what is wrong! It's hard to convince the mechanic that the steering is heavier than before when he turns round and says "but it turns easily enough" and then won't even entertain the fact it gets too heavy at higher speeds. I'm also worried that it is getting worse and one day could just pack up on me when I'm depending on the car.
I'm hoping somebody on here could give me an idea of what the problem could be so I can either go back to the garage in Brussels and tell them what is wrong or if it's a simple thing fix it myself! For the moment I've found spraying some WD40 on the belt seems to make the steering lighter for a while but it just gets heavier again within a few minutes.
Thanks very much in advance for any help!!
Greetings,
Michael
Greetings,
Michael
