E320 CDI Fuel Consumption
llotse
Wirral
E320 CDI
My estate W210 is giving me an average of 32mpg over all types of driving. Best its ever been is 36mpg on a long motorway run. The same car
(saloon) that is used by our taxi co is giving 38mpg average overall types of driving. Is mine bad? if so what might be the reason? (I am over the initial torque addiction and just drive normally now!) My car has covered just 35000 miles whereas the taxis have covered between a 100,000 and 300,000.
Could be the maf, try swapping maf's over with one of your other cars and see if there is any difference, it won't cost you anything.
what tyres do you have???
I have the 235/45/17 option on mine and while i sometimes get over 40 on a long trip my average has for year on year been 34.5mpg.
this time of year i only get into the 30's on a decent trip , local ruinning is mid 20's
I have posted somewhere the official figures for the estate 320CDI but here we go:
City 25.0
Urban Driving Cycle 47.9
Total 35.8
0 - 62.5mph 8.8sec
I am only the messenger here and would suggest the official figures are always on the side of the optimist, however if I was not breaking any speed limits on a motorway then I would expect to see a fuel consuption far better than what your getting. The snag is only you know how heavy that right foot is. :o :devil: :)
Regards
John
City 25.0
Total 35.8
0 - 62.5mph 8.8sec
Regards
John
John
Are those figures not for the S211?
We are talking about a 210 so the figures would be different.
John
I thought the question was related to the 210 320CDI estate so me being me, posdted the figures for.........................
Yup the 210 320CDI estate :devil: :D
Regards
John
Mine did far better than 8.8 0-60 when stock i think i managed a 8.2 which tallied with some other test figures i saw
Oi,
I'm just the messenger :D :D and I did say 0 - 62.5mph (or Mercedes-Benz say 0 - 62.5mph)
I'm sure we have all acheived better figures, our car regularly gets over 90mpg, but when we go up hills it might drop to about 12mpg :o :o
regards
John
In town I average around 20mpg
Long trips average up to 36mpg - if I reset the computer at speed it doesn't seem to show much improvement.
[235/45 17 tyres if that matters]
My long term average is 39MPG. That is mainly motorway driving.
On the motorway on crusie control at 60-65 if i drive up to Leicester from Berkshire i can get up to 49MPG.
On an average motorway run with some heavy footed driving i get 39-41 MPG consitently - hence the long term average of 39.
Round town - difficult to assess but somewhere around 26MPG so if i drive 3-4 miles to get on the motorway on a cold engine it takes a further 25 miles on the motorway before the average gets up 39MPG.
Hope this all makes sense and is of use.
Current mileage is 127,000 and hasnt got better or worse with mileage.
Thanks for all the replies. My tyres are 225 45 17. Will try to be more light footed but then again I bought the car for the extra performance so maybe I will just pay more for fuel. I could change the MAF and if it makes no difference put it on ebay.
Estates will drink 1-2 mpg over the saloon due to different gearing.
Your MPG sounds very similar to my E320 CDI estate. Most motorway journeys average 36-38mpg. Very light footed motorway driving gives me 41-42mpg at most.
The joys of fuel consumption - impossible to compare from person to person really.
Big factors that will affect it:
Weight. If the estate is heavier than the saloon the urban cycle (town driving) will be affected.
Aerodynamics. Saloons tend to have a lower Cd than estates due to the tail being stepped off more gradually, and if the estate has roof rails that will make a difference to the frontal area. Wide tyres increase frontal area too.
Rolling resistance. Underinflated tyres turn movement into heat, sticking brakes etc make a big difference. Try running with tyres at the max recommended inflation (note your roadholding will be affected...)
Winter. Winter diesel tends to have more additives and slightly lower power and therefore you use more. Also your cabin heater (fuel driven) will be in use more and for longer so the start of your journey will use a lot more fuel until the engine warms off - on the 211 you turn it off by disabling the aircon, not sure about the 210, but it saves a lot of fuel.
Driving style. The more you brake, the more you have to accellerate again and the more fuel you will use - anticipation and smoothness is the key.
I drive fast and quite aggressively (not in my opinion but normally that of the white knuckled, pale and trembling passengers) and average 32mpg ish in my 211, days when I'm doing town traffic only are 24-25mpg, motorway is 34-38, and when I'm deliberately being laid back 40-45.
To compare, my A class averaged 38mpg, my Volvo S60 2.0T 22-24mpg.
I expect there's nothing actually wrong with your 210, you'll find a taxi driver will not use the aircon, will have his gearbox trained to economy (drive gently for a week, feel how sluggish it will become and how early it will change up!) and will probably run high tyre pressures and small tyres for cost reasons. Also his being a saloon it's more aerodynamic and probably lighter.
I found mine improved after having all the fluids changed, engine, gearbox and diff. Improved again when I had the B service which changed the airfilter and improved even more when I recently had the thermostat replaced so it is now running correctly at 90c rather then just under 80c.
Last weekend in Somerset, I struggled to get it above 60c...
...is it just highly efficient or should I worry?
I've wondered about my stat for a while - runs at 60-70 with the aircon on (which keeps the rad fans on) but runs 80-90 with it off - is it a bit wrong?
Changed the MAF today and the mpg seems a little better but time will tell
