E63 brake pads
Luke-BITURBO
E63 AMG 725BHP, R35 GTR 700BHP, C63S, GOLF GTI 550BHP
Are there any aftermarket pads out there had to be the only car I cannot find them for
Cheers
EBC do a Yellow Stuff to fit, but I've just bought OE for mine after lots of homework. Got my dealer to price match MB Southend and no problem. £172 for fronts including sensor.
Just can't be bothered putting them in at the moment, too cold for me outside. :(
Yeah can only find ebc but never really been a fan of them, might just have to stick with oem then
I have Ferodo DS2500 pads in mine at the moment. Work really well, but need a wear sensor plug to avoid the pad wear warnings on the dashboard.
BTW, the Brembo caliper used is common across many cars, Audis etc.
I thought the caliper maybe shared but isit still just as simple to install pad sensors?
What car did you buy the Ferrodo's for?
Cheers
Cheers
Same car as yours obviously, I wouldn't have replied with such a random statement otherwise. :dk:;) The E63 TT.
No, there's no recess in the pad for a wear sensor iirc, I'll have to double check though.
I thought you meant you got them listed under a different car which share the same caliper as the e63?
Front pads NON ceramic
Non ceramic vehicles Only
For Oe Ref 0044207620
TRW GDB1734
TRW GDB1734DTE (LOW DUST COMPOUND)
Delphi LP2149
APEC PAD1616
For oe Ref 0064200720
TRW GDB1907
w/s212 e63 Bi-turbo fronts
Usually just cut out the an old pad sensor. Join/solder the wires together and tape/shrink up. Leave the plug in tact and plug this back into the car loom.
Should fool the car. Used to work on old Brembo pads for my Leon.
