jeremy156
I discovered that the front driver's side electric window switch is physically damaged and doesn't rock properly.... and then I also discovered that a rear passenger could drop his window but couldn't get it to rise again... .hmmmmm....
In the absence of a Haynes manual or equivalent being available for the W210 E class, could anyone possibly explain how I approach removing and re-fitting the switches? Most important is the driver's switch next to the gear shifter.
Any advice appreciated
Jeremy
Jeremy
