300-24's can sometimes run a bit hot... mine is the same too an ive changed radiator, thermostat + loads of bits. Always been the same..
Yesterday was fairly warm too?
Given the comments about these engines inherently running hot, and the simplicity of their cooling systems, it might be a candidate for a waterless coolant mod.?
Evans Waterless Engine Coolants
Don't forget something as simple as the coolant cap....
Also the aux fan circuit can be modified to turn on at a lower temp then the stock 105C.
My fans are modified to turn on at 92C.![]()
If you have an air lock you can normally hear some gurgling going on if you move the heater controls from hot to cold and back again. My W202 had an airlock and it got very hot with no heat coming from any vents. Solution was to drop the existing coolant (needed doing anyway) and ensuring heater controls were set to hot refilled it, started engine and topped up as the fluid dropped..been perfect ever since.
I'm pretty sure the early 300-24 engines have a bit of a reputation for liking a head gasket..
Heater matrix shouldn't affect running temperature or overheating.
Cooling systems on these cars are very, very basic. It's just a load of water/coolant pumped around a block and radiator with a thermostat restricting flow to the rad until warmed up. If the thermostat is opening and the water pump is pumping and the hoses/rad are clear then I would suspect blockages in the coolant passages of the head/engine block etc.
I dont know about a gurgling noise but there definately is some sort of rev fluctuation when I turn the fan from position 1 to full speed when on hot, is this the same?
Well.. this is how high it got today just sitting in traffic.. heaters on full.. engine to the point of almost shuddering when about to accelerate. Luckily traffic started moving so it came down to 100. The aux fans were definately on too.
