kamalpatel12448
- Sep 11, 2010
- Location
- London
- C63 (W204) and C240 (W202) - just not at the same time!
Interesting. Can you elaborate on the drain down issue?
MB dealer just gave mine a B service and used 0w40 oil. All previous services used 5w40.
Interesting, which dealer if I may ask?
The drain down issue was applicable to the M156 engine, in particular the earlier ones. I believe there were a number of parts modified in later models e.g. head bolts and buckets etc. The bucket drain down issue essentially meant that if the engine is left standing for a lengthy period of time the oil drained down, hence on start the engine was noisey and rattly, also said to relate to premature cam shaft wear etc. Apparently, this led to the change in oil recommendation of 5w40 to help with this.
I am just an owner and there are better experts here on the forum who can advise, but there are other threads on this forum and others about this.
Hope that helps.
