Hey guys!!!
My E300's motor is back in one piece now and installed in the car... Thanks to all of you.. really appreciate it!
But there is a problem. The motor was still over heating after the overhaul, the temperature was at 90 degrees even at idiling, and overheating was the reason for the overhaul. I have not driven the car yet but i'm sure it will go upto 120 degrees. I think there is some thing wrong with the coolant circulation, because half of the radiator was cold while half was hot and the engine itself was burning hot. We did get rid of all the air in the system and also took out the thermo valve but theres no difference.
Would anyone know whats wrong with the car, i will get the water pump removed and checked tomorrow although i did check it during the overhaul and it was rotating fine, but it was not seperated from the assembly so i couldnt see the blades.
DIESELMAN!
I found the marks on the cam, crank and the port on the side of the injection pump and i got the locking tool made from a local blacksmith. But i cant really understand how do i align the injection pump with the 14 deg. mark on the crank pulley. Do i have to remove the vacuum pump for that?? Is there any mark on the injection pump pulley which i have to align with crank pulley @ 14 deg.??
Pleaseee helppp!!!!
