Err...strange clear oily liquid leaking from front of Transmission (not trans fluid)
golden1245
1999 C230K Sport
Sorry for all the transmission questions...I drove my car around today and then got under it to do some preliminary research on the ATF change.
I then i noticed this strange clear yellowish fluid leaking onto the floor, from the front of the transmission (is that the torque converter)? It was not dark, but a clear fluid, almost like water but slightly slick and oily, slowly dripping 2-3 times. I took a couple pictures so you could see:
Does anyone know what this is and if it is a serious problem? I'm about to spend $800-1000 overhauling certain parts of the car, but if this is early signs of a transmission failure or something very serious, I'm not sure if I want to proceed...
Thank you in advance for reading, it's much appreciated since the American benz forums are not very helpful.
Sounds like coolant dripping off the back of the engine... does you car have the yellow or green coolant?
When I had coolant popping up in about the same place it turned out to be the head gasket. Diagnosed and repaired by PCS but still very expensive.
taste sweet? um..should I rub a bit of it off the ground and put it on my tongue? I could try that if that's what you mean.
head gasket...that sounds really really expensive, i thought the c230k's were quite reliable in terms of stuff like that.
It could be just a split hose or leaking joint... needs to be diagnosed.
