- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Had a bulb failure warning earlier for the offside rear indicator on the W203.
I have changed the bulb (tried 3others including the known good bulb) but still the same problem. I also swopped over the rear lamp clusters and the problem stays on that side.
All contacts looked clean but I have cleaned them anyway and wiggled the wiring to the connector with no effect.
The indicator bulb will illuminate for a few cycles each time the indicators or hazard switch is operated but then goes out again so is this a rear SAM problem?
Thanks in advance.
Thanks in advance.
