striker600
- Nov 13, 2007
- Location
- south yorkshire
- 2001 c270 cdi avantgarde estate Auto w203
Hello all.The ESP fault has just appeared on dash display
.I tried twice to clear it doing the steering lock to lock 3 times which has cleared it in the past,when disconnecting battery.
All i have done today is replace the lower off side track control arm,as the rubber cover was split on ball joint.I have also bled all brakes as they were due(2years last bleed).Had a couple of drives 2 ish miles each and all was fine.parked up for a couple of hours,then just covered 15 mile journey, when halfway through ESP fault showed. Any idears anyone?
There is some sort of movement sensor attached to anti roll bar on off side.What is this? I was carfull not to Knock it whilst Changing lower track control arm.
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
