D
Deleted member 55947
Guest
Knob in an EV would be a Knob in an ICE, same difference
They are just trying to save the planet quicker. Either that or consume as much electricity as they can in the shortest possible time.I fail to see why EV's have to be so fast. Some have intergalactic 0-62 times, Tesla Model S for example is under 3.0 seconds FFS. !! All seems a little pointless in today's trafic/road conditions![]()
Emergency brakes should kick in, but like with most aids it’s not guaranteed and the onus is on the driver at all times!@clk320x as our resident Tesla expert, would a Model Y have intervened, by braking and steering away from the hazard?
The reason that I ask is that it was genuinely miraculous that he missed the cyclist, once committed at that rate of acceleration, I’m not sure human reaction would be quick enough to get on the brakes.
At low speeds there’s also a feature called ‘Obstacle aware acceleration’, so if a car or garage door etc etc was directly in front of the driver and you used WOT torque from the motor would be limited to a safer level!
Having watched and rewatched the dashcam video footage a few times now, I’m relatively confident that the driver kept his foot flat to the floor the whole time and only backed off several seconds after he had passed the pedestrian and cyclist. ’m relatively confident that it was the Automatic Emergency Braking which intervened momentarily and saved the day.Emergency brakes should kick in, but like with most aids it’s not guaranteed and the onus is on the driver at all times!
I think more than anything the collision warning system started beeping at him and he let go of the throttle!
Info below:
Model Y is designed to determine the distance from a detected object traveling in front of it. When a frontal collision is considered unavoidable, Automatic Emergency Braking is designed to apply the brakes to reduce the vehicle's speed and therefore, the severity of the impact. The amount of speed that is reduced depends on many factors, including driving speed and environment.
When Automatic Emergency Braking applies the brakes, the touchscreen displays a visual warning and sounds a chime. You may also notice abrupt downward movement of the brake pedal. The brake lights turn on to alert other road users that you are slowing down.
Emergency braking in progress
Automatic Emergency Braking operates only when driving between approximately 3 mph (5 km/h) and 90 mph (150 km/h).
Multi-Collision Braking
In addition to Automatic Emergency Braking, your vehicle may apply the brakes to prevent or mitigate a subsequent impact after an initial collision if airbag deployment is detected. The brakes may be applied regardless of driving speed.
Obstacle-Aware Acceleration
Obstacle-Aware Acceleration is designed to reduce the impact of a collision by reducing motor torque and in some cases applying the brakes, if Model Ydetects an object in its driving path. The touchscreen displays a visual warning and sounds a chime when the brakes are automatically applied. For example, Model Y, while parked in front of a closed garage door with Drive engaged, detects that you have pressed hard on the accelerator pedal. Although Model Y still accelerates and hits the garage door, the reduced torque may result in less damage.
Obstacle-Aware Acceleration is designed to operate only when all of these conditions are simultaneously met:
- Drive or Reverse is engaged.
- Model Y is stopped or traveling less than 10 mph (16 km/h).
- Model Y detects an object in its immediate driving path.
...Being less flip as a cyclist EV's do have an uncanny ability to materialise just behind you without you hearing them. Not good.
But a Cyclist won’t do you as much damage as an EV although granted it will still hurt.And so do cyclists who approach you from behind while cycling on the pavement.....
It’s not pointless at all.I fail to see why EV's have to be so fast. Some have intergalactic 0-62 times, Tesla Model S for example is under 3.0 seconds FFS. !! All seems a little pointless in today's trafic/road conditions![]()
Not really related to my point at all but hope springs eternal that EV drivers are aware they are driving a largely silent vehicle (bar a faint hum at low city speeds) and act accordingly (be cautious) when in the vacinity of cyclists. The sound of approaching vehicles is part of a cyclists spatial awareness and EV's do not produce the familiar vehicle sounds.And so do cyclists who approach you from behind while cycling on the pavement.....
All I can say is that I have never felt the need for a 0-62 of less than 3 seconds. OK, as a youngster fast cars were our dream but as you mature you realise the pointlessness of it all and the danger you are presenting to other road users. My car has a 0-62 of 7.2 seconds which is ample for what I have ever needed. In the modern world there is no need for itIt’s not pointless at all.
Having fast acceleration is brilliant when overtaking, or joining on sliproads etc… blame the driver not the car…
Also you’ll find most EV owners drive normally, just because your car can go fast doesn’t mean you have to always drive it that way. I drive mine pretty sedately, at the end of the day accelerating away at every junction just causes unnecessary wear and tear on the drivetrain.
I think you’ll find the same for many (sensible) AMG drivers too - yes you have the performance and use it now and then, but a majority of the time you drive normally.
100% agree with you. Cars are so fast, the fun is over before you realise it even startedAll I can say is that I have never felt the need for a 0-62 of less than 3 seconds. OK, as a youngster fast cars were our dream but as you mature you realise the pointlessness of it all and the danger you are presenting to other road users. My car has a 0-62 of 7.2 seconds which is ample for what I have ever needed. In the modern world there is no need for it![]()
I have experienced a Taycan Turbo S many times and it’s unbelievably fast off the mark. Leaves the M5/AMGs literally for dust.I think that’s likely. And it is faster, he didn’t need to prove it. I think I’m just in shock that I saw what I saw. I think the car intervened and saved the last on a bike’s life.
The point is you don’t need to use the acceleration though, it’s there if you want it. Feel free to buy a slower EV… there’s plenty available now.All I can say is that I have never felt the need for a 0-62 of less than 3 seconds. OK, as a youngster fast cars were our dream but as you mature you realise the pointlessness of it all and the danger you are presenting to other road users. My car has a 0-62 of 7.2 seconds which is ample for what I have ever needed. In the modern world there is no need for it![]()
Sounds like he won’t be using the accelerationOld friend of mine went from a 520d to a dual motor model 3 and he’s scared of it !
P.S. people who don’t want the performance drive Teslas in ‘chill’ mode which reduces the power.
