Exhaust gasket replacement query
W210Virgin
Norn Iron
2002 S210 Avantgarde 320CDi in silver. Black leather interior
Car: I6 3.2 S210, 2002
Problem: gasket leaks at turbo/ cat joint. Can smell the exhaust when in slow traffic and there is soot on the u/s of the air filter box heat shield.
Query: anything I need to know about replacing this? Gasket about £10 from MB and in stock but just want to be prepared. The spring clamp is about £45 :confused::eek: and how do I know if it needs replacement too? Other than that looks like a nice easy change, for once!
It could be leaking due to a partially blocked CAT. It is straight forward to replace the seal. Take the cat out and wash it out with water. A hose pipe lightly squirted does the trick.
Don't want to touch the cat as the mounting bolts/ studs are screwed with rust and look impossible to remove :(. I've looked at the gasket before and I'm sure it's stuffed.
Well, I got it done anyway by moving the cat where it bolts onto the engine just below the manifold. It was still a bit smokey in there so I'm suspecting BlackC55 might have a point or there is a small blow out on the manifold too.
I'm hoping the new seal just needs a good hot run to bed it in.
I presume that if the cat was blocked or partly blocked there would be other symptoms too? Car is running really well and other than a small oil leak on a turbo seal, it's just about fault free at the moment.
