Zu11y
We never install them at night so the customer doesn't drive off with the headlights on, we ensure the beam pattern is as close to oem as possible, so the cars i have done look very close to oem hid lights
Seriously mate you just seem totally against these lights, but you really have no clue (with all respect), i agree some idiots do abuse the lights but a vast majority cannot afford the expensive oem option and use the aftermarkets in the same way they would halogens.
Your view is based on card with reflector headlights using a standard hid bulb, as mentioned before when using a special reflector bulb the dazzle is reduced. Furthermore the majority of newer cars are equipped with projector headlights and when installing an aftermarket kit into these the effect is identical to oem and i have verified this using a beam machine at the garage.
No mate its your opinion, what you have said os true when using a normal bulb, but a h7r is designed to go into a reflector and it replicates the beam pattern very well
Again the left car is a h7r vs the right var which is oem
Make it 100ft, you can see the scatter much better then.I can't be bothered to Google any of this but aren't h7r those mickey mouse bulbs with a little black strip on them?
Can you take some pics of the next kit you fit? Before and after pictures of the beam on a wall from 20ft.
its actually quite surprising as most of the cars we do already have factory hid kits and the owners does not want to pay the stupid cost from the dealers, and in this case its perfectly legal to fit and use an aftermarket hid kit
Yes that got me confused as well... perhaps he is referring to the cost of replacing a failed original HID system (or components of)?
