most cars we do these days are perfectly legal as the law states aftermarket kits are allowed if the headlight is designed to work with a hid bulb.
Just fitted a hid kit on my reflector based W169. I did pick the H7R bulbs and I think it needs a slight bulb alignment after though. Kit is good, decent components and good customer service and speed from HIDs direct. Price is comparable to others, but you get a warranty with these guys.
I bought the 4300k H7R, dipping my beams when I get some time to check the alignment as I suspect it needs a quick tweak. The strip on the top seems to be doing its job in reducing dazzle.
I am not going into the legality. The police are more likely to notice a 8000k (blueish tint?) kit vs 4300k (pure white slightly yellow if anything upon looking at the bulb area itself, it emits white light though), but this is my personal opinion.
I would recommend a kit from them if you need one.
Can post pictures if anyones interested.
Your HID bulbs cannot ever be adjusted correctly, never will. So what you have achieved is you've made your night time visibility worse as well as making it worse for other drivers because you are dazzling them.
And you think this is a good thing?
Sorry but I think you are talking balderdash.
The only headlight designed to work with an HID will already have an HID fitted and therefore won't need any HID kit.
That headlight will also need a self leveling system and wash wipe to be legal.
If you are an auto electrician and deliberately fitting illegal HID kits to cars then you are putting lives at risk as well as causing a menace for other road users.
Do you not understand this?
The scatter was non existent and the beam cut off was very sharp, just like a factory xenon.
Why would you need to fit that kind of burner into a lamp designed for HID?
guys what i mean is when the components fail, hid systems don't last forever, especially in cars such as taxi which are used all night everyday.
i am an auto electrician and hid is a small part of our trade, i was simply saying that it is our responsibility to inform the customer of the legal aspect, it is the same when doing exhausts some systems can cause emissions to fail but if the garage informs their customer then they avoid liability.
it gets annoying when a small number of cars with ill fitted kits give the whole thing a bad reputation.
you wouldn't, a reflect bulb is designed for a reflector headlamp, we would install the oem style ds2 bulb in car with factory hid's
