Factory fitted seats or not....
Vitomonkey
Newport
Vito 109
Hello, another newbie question.
Is there a way to tell if the seats in my van were factory fitted from new or added later in its life ?
It currently has 5 seats in the rear with a gap to fit another. The log book states it's a 9 seater ?? When I got insurance quotes some companies were showing it as dualiner ??
The floor has the quick release rails fitted for both seat rows and looks like it was done properly. After all the searching I did I've not seen any other 9 seaters that weren't fully glazed.
Log book also says it's a compact ??
I'm sure the VIN could be used to find the factory data card which should reveal all. I can't do it but I'm sure a fellow helpful forum member could.
It was possible to spec the Vito with nine seats and no rear windows.
Dualiner means the sliding doors are glazed and there is a second row of seats…same a crew cab in other manufacturer's speak.
It's not unusual for a van with that many seats to have one or some missing. Likely someone traded the van in and kept the seats to sell separately, took them out and damaged them when stored in the garage or they were given away to someone else etc etc….the seats, complete, are worth a few quid as you will have noticed!
Rails can be added reasonably easily; best thing to do is post you VIN asking for a Datacard print as suggested or you could try this site Checking VIN for Mercedes-Benz | CARInfo
Post your vin here and will get you your datacard , that will sort the doubt out.
Nick
Thanks for such a detailed response, you seem to know your stuff !!
Datacard
Identification number: WDF63960123094321 5
Chassis
Sales designation: 109MIX/K4X2 3200
Order number: 5 4 537 07245
Delivery date: 28 09 2004
Paint code 1: 9744 PAINT COLOR, BRIL.SILVER METALLIC MB 9744
Equipment: 1332 No code designation available
Engine no.: 646983 50 088590
Transmission: 716637 00 079306
Engine
Major assembly variant: A 646 010 87 00
Part var. design.: 64698350
Text DER BESTELLTE MOTOR MIT CODE KL5 (KRAFTSTOFFILTER MIT WASSERABSCHEIDER)
IST NICHT LIEFERBAR.
BITTE MOTOR A 646 010 78 00 VERWENDEN UND KRAFTSTOFFILTER,
MOTORLEITUNGSSATZ UND KRAFTSTOFFSCHLAUCH VOM ALTMOTOR UEBERNEHMEN,
ODER LAUT EPC NEU BESTELLEN
THE ORDERED ENGINE WITH CODE KL5 (FUEL FILTER WITH WATER SEPARATOR) IS
NOT AVAILABLE. PLEASE USE ENGINE A 646 010 78 00 AND TAKE THE FUEL FILTER,
THE ENGINE CABLE HARNESS AND THE FUEL HOSE FROM THE OLD ENGINE OR
ALTERNATIVELY ORDER NEW ACCORDING TO EPC
Major assembly variant: A 639 260 23 00 80
Part var. design.: 7166370
SA code
181 No code designation available
213K No code designation available
537L GREAT BRITAIN
581 No code designation available
617K No code designation available
AT8 AXLE RATIO = 4,091
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
EL8 TWO-WAY LOUDSPEAKER FRONT
EU4 AUDIO 10 RADIO WITH SINGLE CD PLAYER
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
FY1 THEFT PROTECTION PACKAGE
GD0 6-SPEED MANUAL TRANSMISSION; NSG250
H00 HOT/COLD AIR DUCT TO PASSENGER COMP.
HF2 POLLEN FILTER
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
IL2 EXPORT CODE
J11 SPEEDOMETER MPH AND KM/H
J64 MAINTENANCE INDICATOR FOR DRY AIR FILTER
J65 OUTSIDE TEMPERATURE INDICATOR
KL3 35 LITER FUEL FROM FACTORY
KL5 FUEL FILTER WITH WATER SEPARATOR
L10 ILLUMINATION FOR LEFT-HAND TRAFFIC
LD0 OVERHEAD CONTROL PANEL WITH 2 READING SPOTLIGHTS
M40 ALTERNATOR 14 V / 200 A
MC1 ENGINE OM646 DE22LA 65KW (88HP) 3800RPM
MF8 LOW-EMISSION VEHICLE EURO 3 GR. II/III
RF8 TIRE MANUFACTURER MICHELIN (80)
RG1 TIRES 205/65 R16
RR7 TIREFIT
RS3 6.5 J X 16 STEEL WHEELS
S02 DRIVER'S SEAT
S23 CO-DRIVER'S SEAT DOUBLE OCCUPANCY
SA7 DOUBLE AIRBAG FOR FRONT PASSENGER, TWO-SEATER
T19 SLIDING DOOR LEFT
T70 CHILD SAFETY LOCK ON DOORS IN PASS. COMP.
U65 SEATING, PASS. COMP., 3-SEAT BENCH SEAT, 1ST ROW
UR0 SEAT MOUNTINGS, VIS-?-VIS POSIT.,1ST REAR SEAT ROW
UR3 REAR SEAT MOUNT W/ QUICK FASTENER; 2 SEAT ROWS
V30 SIDE WALL INTERIOR PANELLING IN CARGO/PASS.COMP.
V43 WOOD FLOOR
VD1 HEADLINER STANDARD, C-/D-PILLAR
VT0 MATEO ANTHRACITE FABRIC
W16 LEFT FRONT WINDOW, FIXED IN SIDE WALL/SLIDING DOOR
W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR
W50 DOUBLE-WING REAR-END DOOR 180 DEGREES W/O WINDOW
X42 PLATES / PRINTED MATERIALS ENGLISH
XA2 WEIGHT VERSION 2940 KG
Z42 APPROVAL AS PASSENGER CAR
ZK4 MIXTO
SA numbers
Group 01
01 522600/02 01 522601/03 01 522602/01 01 522603/04 01 522604/03
01 522605/03 01 522611/03 01 522616/02 01 522634/03 01 522636/03
01 522638/01 01 522639/01 01 522642/03 01 522644/01 01 522645/03
01 522674/01
Group 03
03 522606/01 03 522607/03 03 522608/06 03 522609/03 03 522634/03
03 522640/01 03 522641/01 03 522650/03
Group 05
05 522605/03 05 522610/03 05 522619/02 05 522624/02 05 522629/02
05 522639/01 05 522642/03
Group 07
07 522612/03 07 522613/07 07 522614/03 07 522617/03 07 522647/03
07 522651/03 07 522651/08
Group 09
09 522615/04 09 522615/08 09 522617/03
Group 13
13 522618/03
Group 14
14 522617/03 14 522620/03 14 522673/01
Group 15
15 522603/04 15 522605/03 15 522622/03 15 522630/01 15 522630/06
15 522630/07 15 522630/08 15 522630/09 15 522649/11
Group 18
18 522623/03 18 522625/03 18 522626/01 18 522627/02 18 522629/02
18 522639/01
Group 20
20 522628/02 20 522632/02 20 522661/03 20 522672/03
Group 22
22 522643/03 22 522667/03
Group 25
25 515411/02
Group 26
26 515401/01 26 515402/07 26 515403/01 26 515404/01 26 515405/01
26 515406/01 26 515407/01 26 515409/06 26 515411/02
Other
Body: 3
Datacard
Chassis
Engine
SA code
537L GREAT BRITAIN
HF2 POLLEN FILTER
IL2 EXPORT CODE
RR7 TIREFIT
S02 DRIVER'S SEAT
V43 WOOD FLOOR
ZK4 MIXTO
SA numbers
Group 01
01 522674/01
Group 03
Group 05
Group 07
Group 09
Group 13
13 522618/03
Group 14
Group 15
Group 18
18 522639/01
Group 20
Group 22
Group 25
25 515411/02
Group 26
Other
Body: 3
Amazing !!! Thanks for that !!
Now I'm confused about the whole speed limit problem that seems to a common thing. States its a N1 category on log book so commercial vehicles speed limits. Is that right ?
From the paragraph below the table https://www.gov.uk/speed-limits
"Vans, car-derived vans and dual-purpose vehicles
Most vans under 7.5 tonnes laden (loaded) weight, including Ford Transit vans:
have a lower speed limit than cars
must follow the speed limits for goods vehicles of the same weight
A vehicle qualifying as a ‘car-derived van’ or ‘dual-purpose vehicle’ has the same speed limits as a car."
