The AA, my regular garage, a Merc specialist, a brake specialist and a Merc engineer have all looked at my car and agree there is a real issue, but none know what it is. The latest idea is that it is a gearbox issue. Does anyone on here have an idea or how I can diagnose the issue?
The Symptoms.
Under braking there is a very noticeable vibration through the steering, it is also present but to a lesser degree in the pedal and seat. It is present at all speeds. This feels like it is the front of the car.
Under braking there is a tyre noise that sound like a flat tyre. This noise also comes when the car has been on a long trip 2hr+ when just cruising along over 50 mph.
When descending a steep hill and when the car is on cruise control, I can feel that the car is being held back. I.e. it is as if the gearbox is constantly trying to decelerate the car. (the odd thing is how noticeable this is).
About 12 months ago I stopped to get fuel and when I started the car again, the gears would not engage. I restarted the car and the issue did not repeat itself (This may not be relevant).
Work done but with no effect or negative effect.
On the Front - New AMG discs (replaced twice), pads, bearing, joints on the various arms that connect to the wheel. - no effect
New tyres, balancing - no effect
Attached to the Merc computer - Old faults were cleared and it was re tested. No faults on any systems at all. The car was retested 6 weeks later, still no faults.
The car just had a type A service, the gearbox oil was dirty. The filters were changed etc. After this last service the problem is worse. Now my wife recognises the problem and says her passengers have noticed it too.
The car is a C Class 3.0 C320 CDI Avantgarde SE 7G-Tronic 4dr circa 2005/6 with full service history and 144,000 on the clock. In all other respects the car is great.
Thank you for reading this and trying to help.
The Symptoms.
